When I bought my baby tile saw, I wasn't thinking about replacement blades but apparently I should have been! My saw takes a 7-inch blade. All the good ones I've seen (Crystalite, yellow blazer, etc.) are 6, 8, etc. inches.
Am I crazy or am I not looking in the right places??!?
Need QUALITY 7" diamond saw blade
I have a Harbor Freight 7" OVERHEAD tile saw. I'm using a thin 6" Lopacki blade with 1/2" styrofoam under my glass. I'd like to have a 7" blade for it. While ordering some other diamond products from Lopacki last week, I suggested to the lady taking my order that they should consider 7" blades. She said "I'll talk to Daniel about it."
I'm not sure what you mean by "quality." Lopacki sells "cheap" saw blades which means "not stainless" and "not plated." They cut well. That's the kind of quality which interests me - good value for money.
Wally Venable, Student of glass
Two good blades for an MK saw are MK 215 GL or MK 303 Pro. Both are aprox the same price and both do a good job. Here is a link.
jim
http://www18.iwebcenters.com/protoolsex ... 31251.ctlg
jim
Re: Need QUALITY 7" diamond saw blade
TryCheryl wrote:When I bought my baby tile saw, I wasn't thinking about replacement blades but apparently I should have been! My saw takes a 7-inch blade. All the good ones I've seen (Crystalite, yellow blazer, etc.) are 6, 8, etc. inches.
http://www.hisglassworks.com/index.html
quality diamond blade
Hi,
I have purchased blades from cyrstlite. You need to call them and talk to tech support. Tell them the type of glass you want to cut and they will configure the proper diamond size and how it is bonded to the blade. They will also need the arbor size (hole in the blade) and the outside diameter. They will also want to know how thick you want the blade to be, they can give advise on this when they know what you want to cut.
The last blade I had made was a 7" blade for cutting quartz glass tubing. It cost $250.00
There is a difference between the ceramic, masonry, and glass blades. They have different diamonds and are bound differently.
Marty Daily
Centre DeVerre
Marty Daily
Centre DeVerre
Marty Daily
email: martydaily@verizon.net
how long did it last? that's pretty big $$$
sorry I haven't called - I'm in the midst of selling one house, buying another, living in hotels in between
