Ever try fusing sea glass
CreativeK
Post by CreativeK »
Has anyone ever tried fusing sea glass? Does anyone know the COE?
Thanks for any replies.
Kim
Post by Brock »
It's not gonna work, there will be many different coefficients. You, (or a glass chemist) could probably melt and flux a batch, but just fusing it together is a recipe for disaster. Brock
Re: Ever try fusing sea glass
Kim K wrote:Has anyone ever tried fusing sea glass? Does anyone know the COE?
You can fuse sea glass using glue, not heat.
Or am I wrong and expansion coefficeints will also kill a glued joint?
gone
Post by gone »
It doesn't seem like there would be any point in firing it, since it would lose the surface that makes it special. Most people glue it, or drill holes and hang it. The COE is variable, depending on what it came from; mostly bottles is my guess.
Els
Post by Brock »
I don't know. I think it would be okay. I used to foil it and make lamps out of it. Brock
Linda Reed
Post by Linda Reed »
If you're just looking for the LOOK of sea glass (as opposed to actually having a bunch you are trying to figure out how to use...) you can tumble compatible glass and it gets the same look.
(I did this with a nice batch of puddle I had to chisel off my kiln self once. :oops: . Actually, I ended up using the tumbled glass 'stones' on several things - if you just barely tack fuse, they get a sheen, but still look frosted/matt, the hotter you go the more the matt goes away, but they still have that organic shape.)
Linda
