melted glass on stainless former
jerry keller
Post by jerry keller »
I had a meltdown in the kiln, and have melted glass embedded on a stainless steel former. I tried to get it off by putting in a kiln to 900 degrees, then dropping it into water - a lot of the glass came off, but some remains. I do not want to sandblast it in my booth, as my grit is very fine and I don't want to contaminate it. I was wondering about other techniques to get it off, or also to spray a resist onto it, or kiln wash, and hope that the minor amount of glass still stuck to the surface will not be a problem, as i am just folding vases , not melting glass onto them.
Re: melted glass on stainless former
Do you have diamond hand pads? You may be able to sand it off that way.
Go to a wholesale restaurant supply and ask for a martini shaker. They cost a small fraction of a floral former from a glass supplier. I bought one from each and they were identical.
jerry keller
I also had a ceramic stand that the stainless steel former sat on that got covered with glass. It let the glass slide onto the former, and make the ends of the vase turn a bit. It was 5.5" wide at the base, and was like a gentle slope at the end of the former. Do you have any idea where to get something like this?
Post by rosanna gusler »
i would dremmel it off. r.
charlie
Post by charlie »
[quote="jerry keller"]I had a meltdown in the kiln, and have melted glass embedded on a stainless steel former. I tried to get it off by putting in a kiln to 900 degrees, then dropping it into water - a lot of the glass came off, but some remains. I do not want to sandblast it in my booth, as my grit is very fine and I don't want to contaminate it. I was wondering about other techniques to get it off, or also to spray a resist onto it, or kiln wash, and hope that the minor amount of glass still stuck to the surface will not be a problem, as i am just folding vases , not melting glass onto them.[/quote]
you can sand blast it. it won't contaminate the grit.
Post by Laurie Spray »
Not sure what kind of former.....but if it is one of ours i would just line it with your 1/8" paper and use it. The paper will seperate it from your next work.
