I have a couple of the BE mullite damz that I'd like to make a bit shorter to fit into my 8" Aim kiln. Will they reliably break along a score line when hit with a hammer or pressed over a dowel? Which method recommended?
Cliff
Will mullite break along a score?
Your local tile store/installer would probably cut it for next to nothing. Or someone that installs stone countertops.
Wait, wouldn't one of those brown dry masonry-cutting blades work, if you went really slow? I'm talking table saw or skilsaw- those brown composite type "blades". I think that would work. They make hacksaw type blades that cut ceramic tile, that might work too.
I would saw it before I'd try to snap it on a score.
I agree with Tess that wet is best bet. Is that a Bob Dylan line?
Related question to the group: does it screw up a bandsaw/ring saw/wire saw diamond blade to cut these more clay-based, ceramic and refractory materials? I cut kiln shelves up on my MK tile saw and use the same thin lapidary blade to cut glass. How bad is that exactly? I use a thin lapidary blade.
I want a tool area here for us gearheads....
Phil[/b]
Phil[/b]
home depot. $.25/cutPhil Brown wrote:Your local tile store/installer would probably cut it for next to nothing. Or someone that installs stone countertops.
yes. you can get a masonary blade for a skilsaw for very little. wear breathing apparatus, or you'll be puking brown stuff for a while. damhikt. don't use your table saw unless you're fond of buying motors for it. damhikte.Wait, wouldn't one of those brown dry masonry-cutting blades work, if you went really slow? I'm talking table saw or skilsaw- those brown composite type "blades". I think that would work. They make hacksaw type blades that cut ceramic tile, that might work too.
no. but cutting metal will.Related question to the group: does it screw up a bandsaw/ring saw/wire saw diamond blade to cut these more clay-based, ceramic and refractory materials? I cut kiln shelves up on my MK tile saw and use the same thin lapidary blade to cut glass. How bad is that exactly? I use a thin lapidary blade.
Phil[/b]
