Tile saw question
Jane Morgan
Re: Tile saw question
I'm too used to FB. I wanted to hit like after Bob's post. Good discussion and timely for me. Thanks for all the info on blades, Les.
KaCe
KaCe
Jane Morgan
160294 MK-333JB 10" PORCELAIN DIAMOND BLADE
Here is one of my favorite blades . I saw alot of colour bars and even go 3 inch to 4 inch thick and this is the machine to get the job done
This one tooo is one of my favs.
6073 Dewalt DW4764 10" XP4 Porcelain Diamond Blade 1 $58.95 $58.95
Would you recommend the MK-333JB over the MK-215GL (if you've tried the 215gl)?
thanks,
Jane
Jane Morgan
Cutting is d@amn-near impossible on the swap top, even with a decent blade. My next tool purchase is a tile saw, so I'm paying attentionCaco wrote:Thanks! My budget is going towards a larger kiln so wasn't looking for a huge saw cost. But cutting is getting very old on my swap top!
Jane Morgan
You might want to look at the saw I purchased (the QEP mentioned earlier in this thread). I'm very happy with it.
Jane
Jane
Jane Morgan
Dana, In response to your question about the MK 370 EXP tile saw...be sure to order the one with the metal table. This is only
offered on the EXP or I would order one as a replacement table for my 370. Both my husband and I have a 370 and BOTH have now
warped so much in the middle of the table (sags) that it breaks pattern bars every time and hubby says his breaks tile in the same way.
I called customer support but sadly got the "we sell 3,000 of these every day...blah, blah blah" but as both our saw have the very same
problem (and both are well cared for) I would go with the metal table right from the start. Hope this is helpful...I remember you being helpful to be elsewhere! thanks!
"Windows listen for the announcement of broken glass" ... Anonymous
Jolinda
Jolinda
Thanks for the heads up. I was looking at the exp but had not looked close enough to realize that was one of the differences between the 370 and 370exp.Jolinda wrote:Dana, In response to your question about the MK 370 EXP tile saw...be sure to order the one with the metal table. This is only
