Recommendations on Scales
Shell Kurtis
Post by Shell Kurtis »
I'm looking to buy a scale to use accurately measure glue mixtures, glass for casting and metal for casting. Any recommendations on scales?
Thanks in advance :D
Shell
Buy a postal scale. They're accurate and widely available.
Paul Tarlow
Re: Recommendations on Scales
Post by Paul Tarlow »
Shell wrote:I'm looking to buy a scale to use accurately measure glue mixtures, glass for casting and metal for casting. Any recommendations on scales?
Shell
http://www.oldwillknott.com/
Post by rosanna gusler »
if you know anyone in weightwatchers tm get one of their scales. weighs in gm or lb and has tare function,accurate to .2gm about 20$ rosanna
Shell Kurtis
Thanks for the recommendations. One last question. I was made to believe that in order to mix Hxtal properly you needed a REALLY Accurate scale, preferably digital. Is this correct? Can I really get by on a postal scale?
Thanks again,
Shell
Jerry Barnett
Post by Jerry Barnett »
I use an Ohaus triple beam balance scale for mixing Hxtyl. It is not digital. It measures in grams.
The accuracy of the scale becomes important when you are:
1) Mixing small quantities
2) Correcting the first mix when you overshoot in adding the second part.
Jerry
