I'm just on the cusp of signing a contract to do a cast molded wall 52"x76". It would be sculpted clay, then a plaster/silica mold to put the glass into. My kiln is not anywhere near the size of the opening. I wanted to use metal strips of H channel, or wood to install into the opening. The customer is concerned that the wood would be too large visually, and I'm concerned that the metal, which I cannot seem to locate, would not be strong enough to hold a wall this size together.
Any suggestions on finding H channel, and reinforceemnt for a work this size would be very welcome. Also, any preferences, from those that have had to make this kind of a call?
How to install a 52"x76" wall of cast glass w. a s
My husband's company does a lot of glass wall panels. I know they work a lot with CR Laurence. They usually call them up and talk with someone about what they need then they get faxed specs on the material.
I do know channel for 1/4" is difficult to find. They did find some for a project which cost an arm and leg.
Hope that helps.
Cindy next door
Hope that helps.
Cindy next door
Cindy next door
Jerry,
I just came on board today and saw your question about the cast wall.
I know it has been over six months sinse you posted your question, do you still need advice on this matter?
I am a glazing contractor.
If you still need help, let me know how thick the finished casting is at the perimeter edges and what the existing finished opening is (tile, wood, metal, etc.) that it is going to be mounted in.
Dean Hubbard
Dean Hubbard
Dean Hubbard
http://www.northwestglazing.com
Re: How to install a 52"x76" wall of cast glass w.
Jerryjerry keller wrote:I'm just on the cusp of signing a contract to do a cast molded wall 52"x76". It would be sculpted clay, then a plaster/silica mold to put the glass into. My kiln is not anywhere near the size of the opening. I wanted to use metal strips of H channel, or wood to install into the opening. The customer is concerned that the wood would be too large visually, and I'm concerned that the metal, which I cannot seem to locate, would not be strong enough to hold a wall this size together.
The thickness and weight of the panels is critical to your installation design. I would look to companies that make aluminum frameworks for dalle de verre epoxy panels, like Sussman They are engineered to handle 1" thick epoxy and glass panels that are fairly large. What is your panel size? You might get away with vertical mullions and silicone the glass panels like glass block.
Something I saw at SOFA. There were 3/4 glass panels stacked, and held together vertically/off the floor, with steel cables. The cables could be hidden in U channels cast into the sections. Even if you didn't want to suspend the whole thing, you could use the cables as a front/back stabilizer.
The cable system is used for hanging shelves and that type of thing.
Greg
Greg
