"lost foam" CAD/CAM mould making
Hi, I am new to this board, so perhaps this has been discussed before, but....
I have recently been working with CAD/CAM technologies and glass casting, and am wondering if any one else out there has experience with this process?? I made laser ("LYDAR") scans of my body, which I manipulate in digital 3D modeling programs, then CNC mill master forms in foam, and finally do "lost foam" castings into silica/plaster or Zircar moulds.
I would like to begin working on a large scale (closer to life-size, rather than the doll-size I've been doing) and could use any advice or stories from your experiences...
Sorry for all the acronyms!!
Thanks, Penny
Thanks, Penny
Joe Ruelle
Curious
How do you remove the foam from the mold?
Joe from Wisconsin
Joe from Wisconsin
Nikki ONeill
'finally do "lost foam" castings into silica/plaster or Zircar moulds"
Very curious: what is the foam material and how do you "lose" it. Sounds like an interesting alternative to wax. Isn't Zircar a really expensive but strong material? Would you mind sharing a little of your experience? Thanks.
Curious Nikki
Curious Nikki
John Kurman
I could be wrong, but...
Since this all sounds like "rapid prototyping" that has been done in the metals industry for several decades now, I suspect the foam is the same type - which is your standard polystyrene foam used in insulation and packaging and what have you. Acetone works quite well in removing this type of foam.
If it is something else, then I have no idea.
Ron Coleman
The lost foam technique is used in metal casting. The basic process is make your piece in foam, imbed the foam in casting sand, pour in hot metal and the foam goes up in smoke.Nikki O'Neill wrote:'finally do "lost foam" castings into silica/plaster or Zircar moulds"
Curious Nikki
I suppose in glass casting you could make a plaster mold over the foam and then burn it out and them cast the glass. Its got to be really smelly.
One method I've been messing around with is to make a pattern in Styrofoam (blue board) and then coat it with wax to build up an even layer. After the wax cools, use acetone to dissolve out the Styrofoam and leave the wax shell. Acetone doesn't attack the wax at all, but the foam shrinks up into a blob of goo that needs to be cleaned out. The resulting wax shell is then invested in a plaster/silica mix.
This process works well for closed shapes like vases where the opening is smaller than the body of the piece.
Ron
Hi all.
I've figured most of this out on my own, so I can't say if any of these methods are conventional, but, in no particular order...
the foam i use is just blue or pink insulation foam (easy to scavange for free)
yes, it is the same basic process as rapid prototyping. i have been working at the yale school of architecture, so i don't really know about accessing this equipment in a commercial setting. but i was just curious if anyone has applied this process to art glass, b/c all i have found online is some kinda cheesy suncatchers.
yes, zircar is super expensive, but interesting to work with, very strong and picks up a lot of detail -- AND i had a small grant to cover it
ron - that process sounds really cool, i'll have to try it!! do you find that the acetone produces terrible fumes? do you have any images of your pieces/process? you're right, i just torch the foam outside while wearing a respirator & saftety equipment, but it none the less smells awful. sometimes though, with a relief mould, i can just pop out the foam...
can anyone let me know if there is a way to post pictures on this board and i will put up images of the whole process and some of the results!
take care,
penny
take care,
penny
Ron Coleman
The acetone smell isn't that bad, but you do need good ventilation. I dump in about a half cup and cover the opening with a rag. I check it in a few min and dump out the used acetone.pensterh wrote:
take care,
penny
Here's the first piece I did using this process. I have some others but need to get pictures.
If you have a picture stored anywhere on the web you can add a link to it in your message.
Ron
