Newbie - What do I need?
Chris - L.I.
I have the Kiln and the glass what else should I get? I need help with this so I don't purchase things I will never use. I tend to get carried away when I start something new. Thanks
Paul Tarlow
Re: Newbie - What do I need?
Ditto the suggestion to get Brad's book.Chris - L.I. wrote:I have the Kiln and the glass what else should I get? I need help with this so I don't purchase things I will never use. I tend to get carried away when I start something new. Thanks
As far as tools, materials and supplies -- that really depends on what you want to do. The shopping list for casting, for example, is different from the shopping list for slumping bowls.
- Paul
the morton cutting system and grid are excellent tools, brad's book is a must read, for tacking layers together on a shelf to hold them between work area and kiln, i like elmer's blue gel - you need just a tiny dab so fabric paint applicatiors from your local craft store with the screw on metal top with the very small holes are perfect glue applicators - a couple of rulers and before you fire your first piece, make sure you kiln is LEVEL! this is essential - raid the household toolbox for a level and check the kiln. also a glass cleaning agent - household glass cleaners without phosphorous or amonia are good, other people here have their own preferences - paper towels or lint free rags - lowes/home depot - a sturdy work table, good lighting, if you are on concrete home depot has interlocking mat squares which are wonderfull, they really help minimize leg/foot/back fatique when standing for long periods, a grinder is very usefull, especially when starting to cut glass, the grinder is our friendChris - L.I. wrote:I have the Kiln and the glass what else should I get? I need help with this so I don't purchase things I will never use. I tend to get carried away when I start something new. Thanks
D
