I just got my Felasatti angle grinder, and I have a question about hooking up the water hose. I may just use it in a pan of water without the hookup, but in case I change my mind, here's the question:
The coupler/valve that comes with the grinder needs to be connected with tubing to the water source. What diameter tubing do I need, and how can I connect it to a sink spigot that doesn't have a threaded hose connector?
thanks,
Paul
Felasatti Grinder Water Hookup
Paul Bush
Flying Fish Studio
Portland, Oregon
Flying Fish Studio
Portland, Oregon
Ah always depend on the kindness of . . . hardware store employees.
Take the coupler/valve down to your friendly local hardware store and they'll sort it out for you. Your sink spigot probably has an internal thread and there are couplings for that. Brock
Excellent, my guru. I'm off to Home DepotBrock wrote:Ah always depend on the kindness of . . . hardware store employees.
Paul
Paul Bush
Flying Fish Studio
Portland, Oregon
Flying Fish Studio
Portland, Oregon
Brian and Jenny Blanthorn
Re: Felasatti Grinder Water Hookup
If U have a secert urge 2 BPaul Bush wrote:I just got my Felasatti angle grinder, and I have a question about hooking up the water hose. I may just use it in a pan of water without the hookup, but in case I change my mind, here's the question:
thanks,
Paul
Plummber boy
Put in a dedicated tap
U can never have 2 many
I have about 8 taps in the workshop n approx 40 M of hose
But I hope 2 put some more in soon
Jon Myers
BobB
angle grinder?
I didn't realize you can use an angle grinder for glass working. Are there cutting wheels, grind wheels and polishers that work on an angle grinder that can be used to cold work glass?
I have a couple of angle grinders and really need more cold working equipment.
Thanks in advance.
BobB
Thanks in advance.
BobB
Ron Coleman
Re: angle grinder?
Check out Hisglassworks for all sorts of stuff for angle grinders. The ones most people use for glass are designed to feed water.BobB wrote:I didn't realize you can use an angle grinder for glass working. Are there cutting wheels, grind wheels and polishers that work on an angle grinder that can be used to cold work glass?
Thanks in advance.
BobB
http://hisglassworks.com/index.html Look under products.
Ron
