Kiln Shelf Paper
Kiln Shelf Paper
Does anyone know of a direct supplier for large quantities of shelf Paper...as in Rolls? Thanks for any info you might have.
suzette
kiln shelf Paper
I've actually only used ceramic fiber paper, which is what I was thinking of. However, I am open to all suggestions. Thanks.
suzette
Well, maybe it's not called ceramic fiber paper but that's what I've always thought of it in my head.... don't even remember why that name is in there??
It's the same stuff you're thinking of though... Fiber shelf paper and Fiber Blanket. Fiber paper comes in Thin Fire (paper thin), 1/32" and 1/8" as far as I know. Fiber blanket comes in 1/2" & 1"... maybe wider...
Blanket comes in 25' rolls from Ed Hoy and Fiber Shelf Paper comes in 200' & 400' rolls.
I don't use thin fire but I do use blanket & shelf paper. I use them sparingly because they contain some nasty stuff (a form of silica). When I do use them I try not to move it around more than necessary to keep the fibers from becoming airborne.
~N
~N
Ceramic fiber paper is manufactured by a number of companies inluding Unifrax, Thermal Ceramics and Lydall and is sold under the trade names Fiberfrax, Kaowool and Lytherm. Most can be purchased locally in small or large quantity from your local refractories dealer. These materials are commonly used to repair industrial furnaces and boilers. Look in your local yellow pages under refractories and give them a call. The better papers are clean with a low shot content (unfiberized glass particles) but they cost more.
The catalog description for shelf paper is as follows, "A pure grade of ceramic fiber paper which is ideally suited as a layer between the glass and the kiln shelf. Size: 24" X 24" X 1/32" thick. Leaves a smooth matte finish. Eliminates the need for shelf primer."
The thing I like about this paper is that you can fire on it 3-4 times if you are careful. It seems to be more durable than the Bullseye thinfire. (Perhaps someone has "re-use success tips" for the thinfire.)
Thanks for any info.
suzette
Do a search in the classified section for ceramic fiber. THere was someone selling bulk ceramic fiber there for about $0.80/sq ft which is a decent price for high quality ceramic fiber.
suzette B wrote:The catalog description for shelf paper is as follows, "A pure grade of ceramic fiber paper which is ideally suited as a layer between the glass and the kiln shelf. Size: 24" X 24" X 1/32" thick. Leaves a smooth matte finish. Eliminates the need for shelf primer."
You can get fiber paper on rolls from your local refractory. They should have 24" x 150' rolls (or 250' for the thinner kinds) in thicknesses ranging from 1/32, 1/16, 1/8, and I think I've heard of 1/4 also, although I've never used any that thick. It serves a different purpose than Thinfire, (Bullseye's product- not available at local refractories) which gives you a much smoother finish than other fiber papers. The thinfire can't be re-used, especially the new stuff. In my opinion, this is not an either/or decision - you need both. You can't dam up a piece with thin fire, and you can't hide seams between your shelves with it, but it's function is entirely different. Thinfire is used to get a smooth kiln-washed shelf sort of finish on your pieces without kilnwashing your shelves. I use both in my studio all the time for different purposes.
So I wasn't crazy about the term Ceramic.... if you can't find a dealer locally use some of the names given in this thread plus the term Ceramic Fiber Paper and you should be able to find one online; I know I did at one time but just didn't save the URL.
Luck!
Nancy
PS: I don't use thinfire when I can help it because it turns into a fine powder after use and I don't like to have that in the studio. Kiln wash can be cleaned up by spraying it so it is wet and doesn't become airborne. Lots of folks DO use thin fire; it's just a personal choice..... I do reuse fiber paper but I take care not to move it around much. I use it to lay the 'other' end of the mandrels when I make pendants so the mandrel doesn't roll around and it keeps it level of the end in the pendant doesn't rise up..... I use it to prop up PMC pieces in the kiln too..... I don't like the texture fiber paper gives to the bottom of glass so I don't use it in place of kiln wash. Kiln wash is easy to use and, if you take proper measures, is safe and better as a shelf surface than anything else. IMO. Fiber paper has good uses too..... but different....
Luck!
Nancy
Suzette
You don't give enough info for us to be helpful. Which section of the planet are you shopping in???
There are 2 manufacturers of fiber papers that I know of, Unifrax and Lydall. I have always used Unifrax 970 papers, but I understand that Lydall papers could be a better choice. They have some with higher purity levels, which should result in less sticking. I generally use 1/32" paper and stack it if I want thicker. It comes in 24" and 48" wide rolls.
Both companies have distributors all over. You have to find them in your location. If the yellow pages didn't do it, try the internet.
to Suzette fiber paper
I use the 1/32 paper ONLY,,it does the best job. You have to really peel it off carefully in order to use it again. But i use a rolling pin to make it nice and smooth. i can usually get 3 uses out of it. I tried BE thin paper, and got HUGE bubbles in my glass, so i won't use it again. Hope this helps
Vickie
Vickie
If you still need rolls, I have several rolls of Lydall, 24" - 1/8", and some 12"
1/32". I have these priced at cost.
Lois Clark - Clark Art Glass & Refractories
c1drafly1@cs.com or PH: 276-466-8410 Eastern Standard Time
http://www.uu77.com/thermalinsulation/
They sell fiber products, their blanket is average, I haven't tried the fiber paper.
