Hi there
I am putting the same piece of glass into the kiln for either multiple fusings or  3 separate firings  of fusing, then tack fusing, then slumping .
I was told once that each time you put the piece back into the kiln, you should increase  the time (double it) at the Annealing Temp and half the rate of cooling from A.T.  through to 730F .
Is this the case?  My pieces, post-fuse, are generally 1-3 inches thick...just wanted to check cause that's a lot of hydro...
Suzanne
						re-fusing the same glass
