Polishing using Cerim Oxide
Afternoon everyone - I am having a hard time finding the answers to my questions - I hope someone here can help or point me in the right direction.
I need to use Cerim Oxide on several peices and I am unclear how to go about it. I have a 4" diameter felt polishing wheel - I believe you would make a past of the Cerim Oxide and apply to the felt wheel - do I apply to the top of the wheel or sides? When I apply the felt wheel to polish the glass should I move in circles as I would to polish a car? Could I ruin a piece (make more scratches) by not polishing correctly?
I understand the Cerim Oxide will help remove "small scratches" what I experienced is very small "stretch marks" which of course was due to using Spectrum for stained glass. ( I know, but it was what the client wanted sooo...) I did use my devit spray - the small "stretch marks" are only on the rim of the plates.
I appreciate the help!
Kim
Kim
Kim, try this link to the archives. If the link doesn't work, try searching "Cerium Oxide" in the archives. Good info was posted there a couple or so months ago.
http://www.warmglass.com/phpBB/viewtopi ... highlight=
...Kelly
...Kelly
Re: Polishing using Cerim Oxide
stretch marks happen during your slumping. if you are slumping at appropriate temperatures you should not get devitrification during the slump (though you may have gotten it earlier during a full fuse firing.glassaddict wrote: I understand the Cerim Oxide will help remove "small scratches" what I experienced is very small "stretch marks" which of course was due to using Spectrum for stained glass. ( I know, but it was what the client wanted sooo...) I did use my devit spray - the small "stretch marks" are only on the rim of the plates.
Kim
But back to the stretch marks. They tend to be more likely to happen when you are slumping too fast. What was your firing schedule, what mold did you use, how big and thick was the glass?
Barbara
Barbara[/quote]
Barbara:
The stretch marks happened during the full fuse. I went 200 hr to 1000 then went fast to 1400 (just to get my edges nice and rounded off before slumping). The glass is single thickness and 8" in diameter.
Kim
Barbara[/quote]
Barbara:
Kim
Kelly:KAG wrote:Kim, try this link to the archives. If the link doesn't work, try searching "Cerium Oxide" in the archives. Good info was posted there a couple or so months ago.
...Kelly
Thank you- can't figure out how I missed that during my search - the tutorial at HIS glass is great.
thanks
Kim
Kim, I guess I didn't understand what you meant by stretch marks. And I am confused by your firing. Are you "full fusing" and slumping in the same firing? Or did you do 2 firings, this full fuse and then a slump? Sorry. I must be thick-headed this morning.glassaddict wrote:
Barbara:
Kim
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Barbara
Kim, your first post on this thread mentions you used regular Spectrum instead of System 96 for this project. First, did you grind the edge of your glass? Second, did you apply the anti-devit material to the cut edge of your glass. It sounds to me like you are getting devit on the edges of the plain Sperctrum. The edge of the glass is the same as the face of the glass and needs the same treatment. I have to apply borax solution anti-devit to the edges of my float glass items as well as to the face to avoid devit. There is much about "scum" on ground edges in the archives.
Kay, System 96 is not subject to devit like the regular (stained glass) Spectrum is. Sys 96 should not have the devit problem. Stretch marks do not show up on the cut edge of the glass in my experience. Rather, they show up on the surface of the glass against the mold when the slump is too hot and the glass moves against the mold after it softens enough to deform.
Best wishes,
Tom in Texas
Best wishes,
Tom in Texas
Barbara:
Yes, unfortuantly I had to use "regular" Spectrum for this project. I did a full fuse first just to round off my edges nicely (which worked great) that is when I incurred the stretch marks and devit.
Tomfoolery gave me some great information which was to bevel my edges and then slump thus taking out the first firing - this should get rid of my problem. I know my edges will probably not round off the way I like them however, I can live with the edges but not the stretch marks and devit.
I have a test in the kiln now - also, one of the other bad pieces I used etch creme (dip n etch) and am in the process of firing it to see what happens.
Thanks for your help
