Barbara, thanks for the comments
 I like the lines too
John,
To start answering your questions about the piece:  I have to be honest in saying that this piece is no more than simply a ‘thing in and of itself’. No more, no less was the design intent of the piece other than to be shaped like an eye.
I wish I could give some fantastic story of it’s beginning, development and current state, but I cannot. The piece was created out of simple boredom…a slow day at work…a period in which to doodle and explore shapes, lines and form.
I think if anything and as perhaps as artists should do…is to create works that people will think about in their own way. Perhaps everyone will have a different view and come to their own conclusion about the piece. Is this not a part of the component of art ? With classical music I hear quite often that a piece of music will evoke a story and that listeners ‘know’ what the story is, they say the meaning is clear. I say ‘poohie’ to that. I say you cannot expect people to understand a piece of art or music as the creator intended it to be understood unless you have some advanced knowledge before ever seeing or hearing the piece. It is up to the individual to formulate their own ideas…create their own storyboard.
Knowing what I know now and with your comments and insight I think I will try and approach a new piece that starts with a question or idea instead of purely form and shape.
For your ideas on breaking the piece up….you did read my mind somewhat. The original sketch of the design was indeed separated into 3 or 4 individual pieces. Separated by some space as you suggested. However, I revised that as I sculpted the piece for several reasons…all of which was for cost savings and material usage since this was basically a ‘first’ intended cast sculpture that I was unsure about. The lines came about as a way to capture my original design intent of the piece being separated as best done with practicality of cost and materials savings I had to work with. And I think I did that well…often times design elements can be tweaked to fit that practicality and it works for me.
Anyway, hope that clarifies the piece a little more.
Any other comments truly welcome.
Russ
