Kiln Sitter vs. Controller
Lexie
I have a Duncan Ceramic Kiln, Model#Dk 716-2 with a kiln sitter, Model#Lt3K. Can I replace the kiln sitter with a programmable controller? If so, what brand will work & how do I do it?
Tony Serviente
Don't disable the sitter, just add a controller.
You can use the sitter as a fail-safe to cut the kiln off if the controller malfunctions and the temperature gets too high -- just put a cone in it that's higher than you'd normally fire the kiln.
Then get a standalone controller that the kiln can plug into. Lots of folks make these, including Orton. Several of the kiln manufacturers also offer this kind of model.
