kiln wash on kiln floor?
Michelle Fokos
hi,
thanks to input from Brock, Avery and Barb awhile back i have finally chosen to get a skutt clamshell, and have an electician coming tomorrow to put in my 240 outlet for it!!
i've heard from many folks that it is a good idea to paint the floor of the kiln with kiln wash, but spoke with Neil at Skutt the other day and he disagrees. he feels that coating the floor with kiln wash changes the thermodynamics of the kiln in a negative way. wondering what any of you think about this...
thanks so much,
michelle
thanks so much,
michelle
Tony Serviente
Amy on Salt Spring
I'm no expert in thermodynamics but I can't imagine how a couple of thin coats of kiln wash could have any affect whatsoever on heat distribution in a kiln. What it does do is make any accidents or pieces that roll off the shelf an easy clean up instead of a permanent part of the kiln. I can't count the number of times I've had some doodah slip out of my tweezers and roll off the shelf and under. If I had to take the whole shelf out to get it--well it would be a huge pain. I would think a large buildup of stuck glass would be more likely to change thermodynamics!
Amy
Amy
Re: kiln wash on kiln floor?
One of those "many folks" you may have heard of regarding kiln washing the floor of the kiln is Skutt. The operating manual for their glass kilns recommends that after you kiln wash the shelves "you may also want to coat the floor of the kiln." This is from page 7 of the manual: http://www.skutt.com/glass/resources/op_man.phpmichelle f wrote:i've heard from many folks that it is a good idea to paint the floor of the kiln with kiln wash, but spoke with Neil at Skutt the other day and he disagrees. he feels that coating the floor with kiln wash changes the thermodynamics of the kiln in a negative way. wondering what any of you think about this...
The do strongly (bold print!) tell you to never kiln wash the walls or the lid of the kiln. I wonder if that's what Neil was referring to.
As for me, I think kiln washing the floor makes good sense. You don't have to do it often, but if powder or frit ever spills on the floor (and it will!) you'll be grateful.
Amy on Salt Spring
Do you worry that little motes of plaster dust will float around and get into the glass? I put kiln wash, maybe four thin layers, on the floor of my kiln two years ago and have never recoated and it works just fine still. No need to vacuum up anything or redo anything. Its BE kilnwash--works great and almost no expense whatsoever.
Amy
Amy
Not really. I kiln wash the floor, then forget it. No need to ever re-apply unless you have a disaster.Paul Stevenson wrote:I sift plaster on the floor (with a liberated flour sieve) and vaccuum it out with a mini car-vac every couple of firings and then sift some more.
Plaster is cheaper than kiln wash, that's all.
You all have me thinking. My kiln is a used ceramic kiln. It looks like it had been previously washed, but should I add to it? You don't have to remove the old do you? If so how? Is there a difference between ceramic & glass kiln wash (in regards to the bottom of the kiln only)?
Thanks - Steph
Thanks - Steph
Stephie
Cynthia
What is the floor of this kiln made of, fire brick, fiber board? Glass can erode through brick or RCF materials over time. I would wash it regardless to protect the floor of the kiln. It's possible it might change the thermodynamics somewhat, but the kiln isn't so big that it would be significant (this kiln has a 20" shelf right?), but that's just a hunch on my part.michelle f wrote:...i've heard from many folks that it is a good idea to paint the floor of the kiln with kiln wash, but spoke with Neil at Skutt the other day and he disagrees. he feels that coating the floor with kiln wash changes the thermodynamics of the kiln in a negative way. wondering what any of you think about this...
thanks so much,
michelle
jerry flanary
Judi Charlson
KIln wash on bottom
I kiln washed the bottom of my new kin leaving an inch boarder from sides. I was told a long time ago that Kiln wash should never come in contact with elements
In my old ceramic Skutt kin I always placed a layer of course grog on the bottom. any spills collected on that. I always used grog under ceramic sculptures when firing on shelves to let the sculpture move around a bit to prevent cracks or to level it. I also use grog under plaster molds to level and also think it alows for it to move slightly without friction. It also protects any frit from falling on shelf if I fill the mold after it is in kiln.I really don't know where I got that idea or if it really helps.
Judi
Judi
having just opened the kiln to see the results of this morning's firing, i have the perfect example of why one applies kiln wash to the floor of the kiln ;P the base piece of glass did something unexpected and some of it is down the side of the shelf and puddled on the floor ;P ah well, some of it will become cabs ;P some will go in the recycle bin ;P apparently the kiln goddess felt like playing in my kiln today ;Pmichelle f wrote:hi,
thanks so much,
michelle
D
kiln wash on floor
I kiled washed the floor when my kiln was new. Recently I raked and glass spilled onto floor....When I removed the warm cabs from the floor the next day some of the brick floor came off with the cabs leaving indentations in the brick.....So upsetting....Should I reapply washto those areas?
jerry flanary
Jerry
Washing the floor
Some time back I did a 14" round combed piece which I didn't keep an eye on, and it grew to OVER 20". I say "over" because that's the size of my shelf and it was off the shelf on three sides. I recoated the floor with new wash after that and never looked back, but I do pay a little more attention.
Jerry
Jerry
Michelle Fokos
thanks for all the replies!
the floor of the clamshell is fire brick, and i am going to coat it with kiln wash. the person i spoke with at skutt was aware that the manual recommended this process, but he was in disagreement with it. but it sounds like a very tried and true method to me.
the electrician is here right now putting in my new outlet!! yippee!!
thanks again,
michelle
thanks again,
michelle
