newcomer - question about glass painting
karnor
Post by karnor »
I'm learning how to paint plaques for a friend who builds stained glass windows. I'm using the Reusche paints (tracing black, enamels, etc). Things have gone pretty well, but I have a question I'm hoping someone can answer...
When I fire the plaques, some of the painting on them has a matte appearance and some has a semi-gloss appearance. The only possible factor that I have found that may be causing the difference is which shelf they are placed on when firing. I didn't pay attention in the first several firings as to the position, but in the last few, it seems the ones on the top shelf have the semi-gloss finish (which is what I want) and the ones on the lower shelves have the matte finish.
Any ideas or suggestions? I have the space to fire at least 6 plaques at a time - but don't want to end up with 2 glossy and 4 matte.
Don Burt
Re: newcomer - question about glass painting
Post by Don Burt »
karnor wrote: clip
I don't think the issue is any more complicated than what you suspect. Or that theres an easy resolution like flux overspray. I think you'll just have to increase either heat or time or both and be alert for excessive burn-off of pigment on the upper shelves. I'd try a 10 minute soak after the top layer looks right.
The Hobbyist
Fuse Master and patina
Post by The Hobbyist »
I just finished a big SG project that involved painting some of the pieces. I used Fuse Master transaparent paints and fired to the recommended temp (1175 *F). When I applied black patina to the piece the paint was attacked and much of it came off. It didn't make my day!
I have never had that happen before so I must assume it's the Fuse Master paints.
You can bet I'll be using something else in the future.
The Hobbyist......................Jim
ps. Here's the panel (52 x 38 in.):
karnor
Beautiful work, Jim - thanks to both for your reply (more)
Post by karnor »
I'm a novice at this - but I haven't had any trouble with the Reusche paints once I figured out my own formula for ratio of paint / gum arabic / vinegar.
I think that I'm going to experiment with some of the matte pieces by refiring after using the clear coat overglaze by Fuse Master. Maybe it will help me salvage some of the pieces that have the matte finish and cover up some of the pieces where the glass is not reacting well and losing its gloss as well.
Don Burt
Re: Beautiful work, Jim - thanks to both for your reply (mor
Post by Don Burt »
karnor wrote:I'm a novice at this - but I haven't had any trouble with the Reusche paints once I figured out my own formula for ratio of paint / gum arabic / vinegar.
If you're willing to refire the matte ones, why not just put them on the top shelf toattain gloss? I wouldn't put a low-fire overcoat like fuse master on top of Reusche paints. I think you're asking for trouble with that. Sure would do a test first.
Also, the low fire fuse master overcoat isn't going to be as durable as a gloss fired regular paint. And one last thing: if the paints going to be in a window, nobody's going to notice how glossy it is.
karnor
re: in window...
Post by karnor »
The man I'm doing them for said that they are fine with him, and they are for windows. I guess I just wanted a little uniformity. °Ü°
Thanks for the input!
Re: Fuse Master and patina
Jim Wolverton wrote:I just finished a big SG project that involved painting some of the pieces. I used Fuse Master transaparent paints and fired to the recommended temp (1175 *F). When I applied black patina to the piece the paint was attacked and much of it came off. It didn't make my day!
Jim
Black patina is nitric acid. Nitric will attack any enamel on the market. They are primarily alkaline resistant so that dishwasher soap will not dissolve them. They are also somewhat acid resistant, but it is more for vinegar not nitric.
I experienced the same thing on the most important stained glass window I made in my leaded glass career. Fortunately I saw the stencil black disappearing, figured out what was going on and stopped it with water and baking soda before it was all gone.
I used acid to my advantage when trying to match enamels that had pretty much dissolved over the years when doing a repair. I enameled and dissolved it until it matched the existing colors.
Don't give up on the Fusemaster enamels, just be very careful using black patina.
Dani
Post by Dani »
Just a quick comment.... sorry I haven't answered sooner. I'm in the midst of a writing project and haven't had time to visit. If you've bought the Reusche paint recently, we've been having some problems with some of the black not wanting to fire out... just what you describe with the matte areas. Even Michael who has painted for 30 years with Reusches is perplexed. I suspect we got a batch that was a little "off" or their formula changed.... less lead maybe? Haven't contacted Jon Rarick at Reusche about it yet. Just my two.... hi to everyone! I'll check back in a couple of weeks. I haven't even thought about my mags much less started them! Sheesh, you hotdogs. :wink:
Dani wrote:Just a quick comment.... sorry I haven't answered sooner. I'm in the midst of a writing project and haven't had time to visit. If you've bought the Reusche paint recently, we've been having some problems with some of the black not wanting to fire out... just what you describe with the matte areas. Even Michael who has painted for 30 years with Reusches is perplexed. I suspect we got a batch that was a little "off" or their formula changed.... less lead maybe? Haven't contacted Jon Rarick at Reusche about it yet. Just my two.... hi to everyone! I'll check back in a couple of weeks. I haven't even thought about my mags much less started them! Sheesh, you hotdogs. :wink:
Dani
Try adding some flux or overpainting with flux.
