I cut a 6" white tile (system 96) capped it with clear and put black zebra stripes on top of the clear with some black frit in between the stripes.
Following the 96 firing schedule, I ramped 600dph to 1100 and held for 10 minutes. For some reason I felt I needed to check it. When I looked, the white base layer had split into 2 pieces and had slid away from each other so it was sticking out from the clear on both sides about 1". I did not take the firing any higher and skipped to annealing at 950 for 30 minutes, then cooled to room temp.
The next day, I had to cut the edges of the xtra white off and piece in another section of white in the middle where there was a space under the clear. I used hotline fusing glue and added white frit in the cracks.
I re-fired at 400dph again to 1100 and held for 10 minutes. Then full power to 1450 for 20 minutes. Annealed and cooled.
Next morning, I opened the kiln and there were more cracks in the white under the clear that were different from the first cracks, although these were fused together. I also noticed that some of the black stripes had broke into 2 pieces and had fused with a very faint space between. I was really disappointed. I have a box lid I want to put this in and it didn't quite fit so I took it into the grinder and began to grind a little off and planned to fire polish it and all of a sudden it broke into two chunks! I cleaned it up and checked it under my stressometer and couldn't see any stress. What the heck happened? I want to make another one but don't want to waste the glass again. Any ideas? I'm dumbfounded.
Christyn
