High Temp Fire & Kiln Wash
Mira
Post by Mira »
Recently I did a High temp fire (1700 deg.) I thought all was well, but my piece broke up into several pieces. I figured out what went wrong with my schedule, but before I try again, I just wanted to check one more thing:
Is there any problem with using kiln wash with a high temp fire? I think my glass also stuck to the shelf, contributing to my problem, and I'm hoping it's just a case of a poorly prepped shelf.
Many thanks for the help!
Mira
Post by Brock »
. . . . Is there any problem with using kiln wash with a high temp fire? I think my glass also stuck to the shelf, contributing to my problem, and I'm hoping it's just a case of a poorly prepped shelf.
Absolutely not. Put on several (many) coats and go for it. Brock
__________________
Just because you're paranoid doesn't mean someone isn't following you.
Mira
Post by Mira »
Thanks Brock! We'll give it a whirl tomorrow.
Mira
Amy Schleif-Mohr
Post by Amy Schleif-Mohr »
Brock's right, I use many many coats and mix it like heavy cream. Do expect some sticking to the glass though. Sometimes I get a piece that doesn't stick, but most of the time it sticks and has to be cleaned off.
Amy
charlie
Post by charlie »
need more info. it could be a badly annealed piece. we'd need thickness and schedule.
