Covington's 16" Glass Smoother?
Terri Johanson
Greetings All:
I'm wondering if anyone has used the Covington's 16" glass smoother and how you'd compare its utility to a wet belt sander.
Terri
Terri
Terri Johanson
Thanks Brock. Just what I wanted to know. Do you think the Covington is a good bet for WBS or are there others that I should consider? Is the Model 760 or 761 big enough? I've only worked on other people's in classes and they've always been the floor size ones...and I see that Anea is selling hers because she's getting a larger one.
...Just finally retired and gearing up for nearly FT glass work the WBS is the next piece of equipment I've targeted and am trying to finalize decision.
Terri
Terri
I don't have any experience with the table top WBS's, but at half the cost of a real one, I'd go for the real one. BrockTerri Johanson wrote:Thanks Brock. Just what I wanted to know. Do you think the Covington is a good bet for WBS or are there others that I should consider? Is the Model 760 or 761 big enough? I've only worked on other people's in classes and they've always been the floor size ones...and I see that Anea is selling hers because she's getting a larger one.
Terri
Amy Schleif-Mohr
I have the 3 x 41.5" Covington. Here is my observation.
If you are going to be doing a fair amount of work with it I would suggest getting the bigger floor standing models. I use mine pretty much on a daily basis and ended up getting dimond belts for it because they last longer. Because of this it has cost me just about the same amount as a floor model.
Amy
Amy
Tom Fuhrman
I have both the welt belt sander 4 X 132 and a couple of old Somaca horizontal grinders 24". I use them all every day. They do different types of work. I had a 16" Covington and traded it off as I thought it was too light weight and was not as an aggressive machine as I was accustomed to using. Go for the largest you can afford and have the space for and you'll never regret it. Tenn. Tom http://www.fuhrmanglass.com
but diamond belts for the large one would have been far more, bring the total cost way up there.Amy Schleif-Mohr wrote:I have the 3 x 41.5" Covington. Here is my observation.
Amy
i also have the 3x41.5 covington and use it on almost every piece i produce. however, i only produce a couple of items/month so it's just fine for me.
it will all depend upon how much you use it, and how much production work you do. the table top ones are just fine if you don't mind the slowness of using it, and the belts wear out faster than the large floor standing ones.
Amy Schleif-Mohr
Either Diamond or Silicon Carbide belts last much lomger on the bigger sanders. Seeing as thre belts are your main cost, once you have the machine, the larger units are more cost effective, over time. Brockcharlie wrote:i think the floor standing model belts wear out fast too, compared to diamond ones for that model. there's just a larger surface area so it takes a bit longer.
Patty Gray
One thing to consider is the original cost of the diamond belts. For a smaller machine the belt cost "lots" less. I believe my diamond belts for the floor model was around $850 each or somewhere around there. If you take care of the belts and don't abuse them the diamond belts last a very long time. Everything depends on what you can afford and where you are going to put the machine.
Patty
http://www.pattygray.com
Patty
Terri Johanson
After all your good advice I want to research a floor model WBS...sounds like it would be worth the investment in the long run. I find the belts in several product listings but not the machines themselves does someone have link/s to vendors that handle the floor models...any brand recommendations or cautions?
Terri
Terri
Kathie Karancz
Rick Wilton
Kathie, we have a CRL right here in Calgary, There down basically at the corner of Deerfoot and Barlow in the south.
If you are still interested in coming by and seeing my shop let me know.
I'm not going to be in much between now and Jan 5. but give me a call and we'll set something up.
Rick Wilton
Rick Wilton
Rick Wilton
Kathie Karancz
Kathie Karancz
