Hello,
I am working on a tack fused panel (16"x 35") and I would like to make sure that after it's fired there is not residual annealing stress in the glass. I saw polarized lens test being mentioned as a way to detect stress, but I wonder if it applies to annealing stress as well as to incompatibility stress or to the last one only.
Thank you!
Annealing stress test
Re: Annealing stress test
It applies to stress, however induced.
Brock,
thank you for the fast reply.
On a large piece as mine (16"x 35") I probably need some special equipment to conduct it properly otherwise it would be hard to move two pieces of polarized film on two sides of panel...
No, you're okay. Sit the piece up on blocks on top of a light source and just move the films around to check areas. One on top, one on the bottom, and hold the films so that you have the darkest possible configuration.
That is great! Thank you again.
Yep. One thing: It doesn't work all that well on opaque glass...
And if you need to buy the material, this is a great place to do so...
http://www.polarization.com/polarshop/
(I am nothing more than a satisfied customer)
Guy
Guy
If anyone needs polarized film but doesn't want to "Buy" it, many of the 3D glass are made with polarized film. The new IMAX 3d glasses give you two rather large pieces that'll work great for stress tests.
Rick Wilton
A minor addition. Can you position the 'back' polarized film on the light source.Brock wrote:No, you're okay. Sit the piece up on blocks on top of a light source and just move the films around to check areas. One on top, one on the bottom, and hold the films so that you have the darkest possible configuration.
Then you need only to move the other.
I hate gymnastics
-lauri
