masks
				KissMyGlass
masks
I have a new mask mold.  I thought I'd use the spray instead of kiln wash due to the tiny places.  It is a pretty deep mold.  Do I cut the glass slightly larger that the edge of the mold?  Anybody have any pointers?
						Re: masks
What kind of spray are you talking about?  Remember, boron nitride is for stainless steel, not ceramic.  If your mold is ceramic, you might try Primo Primer.  It can be brushed or sprayed, and is easily removed after firing so detail doesn't get clogged up.
							Lynn g
				PaulaKelly
Re: masks
I've used Boron spray on ceramic molds without any problems...especially molds with fine details that the kiln wash could obscure.  The only thing to remember is that you cant switch back and forth--once you use boron on the ceramics, it seals it; the kiln wash won't stick afterwards.
				jim simmons
Re: masks
What Paula says   :>)
Jim
						Jim
PaulaKelly wrote:I've used Boron spray on ceramic molds without any problems...especially molds with fine details that the kiln wash could obscure. The only thing to remember is that you cant switch back and forth--once you use boron on the ceramics, it seals it; the kiln wash won't stick afterwards.
