Cleaning glass
Cleaning glass
Having a bit of a problem with cutters oil left on small pieces of glass layered on top of larger piece. Was curious how most of you pros clean your pieces prior to fusing. Thanks!
Clean machine
Water. Lots of water. I often put small pieces in a strainer and then rinse each piece individually and wipe dry with a Bounty paper towel. I then spray each piece with Isopropyl alchohol and wipe with a clean paper towel.
Andrew
Andrew
scooter riegelsperger
I have a very easy solution to oil residue from cutters. Quit using it. I cut ALOT of glass & never use oil. I've tried it & get no different results. The only thing I got from it was oily glass. I do still wash everything before fusing, 1st in mild detergent, dry, then methyl alchohol wash & dry.[/b]
Do illiterate people get the full effect of alphabet soup?
Tony Serviente
Kim Bellis
