stencil cutter
stencil cutter
Post by Laurie Spray »
Has anyone used one of these??
http://www.misterart.com/crafts/stencil ... g-kit.html
comments? something better? :-k
thanks,
Re: stencil cutter
I've used a different brand, but it looks similar. Works very well for cutting contact paper or thin vinyl resist.
tbach
Re: stencil cutter
Post by tbach »
Yes I have, and it works very well. For me, it was a lot cleaner cut than I got using xacto knife. It was also a lot faster.
Don Burt
Re: stencil cutter
Post by Don Burt »
I use one. I stencil for airbrush mostly. I replace the cutting tip with a small brass round head bolt and use it to hold a sewing needle. I run it through a soldering iron temperature control at about half power that it doesn't overheat the needle and cause it to quickly lose temper. Even so, I replace the sewing needles after a few minutes of cutting because a sharp point makes for the most precise cut.
Cynthia O
Re: stencil cutter
Post by Cynthia O »
Buy extra tips (or use Don's trick). I don't have a resistor, so my iron is always on full heat. Anyway...I use a hone (those diamond plated hones you can get from Harbor Freight) and resharpen the tips as they dull.
http://www.harborfreight.com/3-piece-2- ... 36799.html
I've only used this tool for cutting thin resist. An exacto is better for thicker resist or buttercut.
http://cynthiaoliver.blogspot.com/
"A happy childhood has spoiled many a promising life."
Robertson Davies
Re: stencil cutter
thanks everyone!!!
