Using a Ceramic Kiln for Warm Glass - Anyone Using Baffles?
Hi guys,
I am a ceramic artist who's recently become a glass fusing addict. I already own a Skutt 1027, which has no lid elements, and would like to fire glass in this ceramic kiln using multiple shelving levels during each firing. Someone in one of my glass classes told me that I could use fiber board baffles/walls at the edges of each kiln shelf in order to regulate the heat that comes from the wall elements, making the fusing process more even in the end and creating a better and more standardized result. So, I've bought the fiber board and intend to cut it into 2" high blocks, fire to remove impurities/binders, and then use these little, re-usable rectangular blocks to line each shelf before warm fusing.
Has anyone done this before? Is there a better way to use a ceramic kiln to fire glass evenly? If so, can you share, please? I spent a lot on the fiber board and can return it if I need to but wanted to get your advice first. Help, please?
Re: Using a Ceramic Kiln for Warm Glass - Anyone Using Baffl
i have that same kiln and regularily fire multiple shelf loads of glass. no need to baffle. if you have zone controll on your controller and use an envrionvent it is super easy. if not , it is still way dooable. tell me more about your kiln and controller and i can help. rosanna
Just be sure to put at least 6" stilts between your shelfs to get good air and heat flow and you will be fine. The only thing I do not fire in my side fire kilns is large pieces where the sides will heat up before the center causing bubbles galore. Anything 10" or smaller is a go for me. I have a tall skutt (can't think of the #) and I can fire 6 shelves in it at once. Great production loads..... I do also slow down my schedule all around from what I use in my top firing genesis.
Stephen Richard
Hi April.
I didn't know you were doing fusing now too.
Steve
Steve
Laurie and Rosanna,
I know that all kilns are different and each one requires testing to determine its proper firing schedule, but would either or both of you be willing to share your schedules for fusing 2 layers of 3mm Coe 90 glass and for slumping the results of that firing? I have a 7 cu ft L&L with a downdraft vent and would love to be able to use it for multiple items.
Jennifer
Jennifer
Jennifer...
I would try
250 hr to 1250 hold till looks done..anneal....maybe no hold at all. Depends on shapes.
Do a test load and see how that goes. Be sure to space your shelves well. I don't know what shape or size your shelves are but be sure to have your larger pieces towards the center of the shelf. If you ever slump lg bowls be sure to have them centered and then you can put littles around the edges.
I would try
Many thanks Laurie. Do you fuse as well as slump in a multi-shelf kiln? If so, what would your schedule be for that?
Jennifer
Jennifer
Depends on the size of the shelf and what you are firing. Experiment and keep notes. You may find the bottom shelf is cooler and perfect for textural relief pieces....... or they may all fire the same if spaced well.
Dairy Queen
Laurie, are you saying the edges round at 1250 with a hold?
Rose
Rose
Dairy Queen
BTW, baffles will change the temp in zones, which will not be read by your pyrometer.
Rose.......not fused of course.....1250 for a slump
Jennifer
Just experiment and keep good notes..... Be sure to put in a good bubble squeeze.
Jennifer
Laurie Spray wrote:Rose.......not fused of course.....1250 for a slump
Jennifer
Thanks Laurie,
I'll be sure to try it out.
Jennifer
