Keeping the drains clear
Dolores
Post by Dolores »
Hello all,
I'm currently revamping my glass studio and need to install some sort of trap on my drain to prevent glass powder from clogging my sewer line. What contraption and/or device and/or brand do you all use? Is it an easy DIY? Thanks in advance!
DOLORES
Re: Keeping the drains clear
Post by Kevin Midgley »
A restaurant grease trap or two of them may be simplest.
GuyKass
Post by GuyKass »
This is about as simple as it gets...
I think Cynthia Morgan posted about it ages ago.
http://www.artmolds.com/product_details ... ter%20Trap
You can also do a Google search "artist sink trap"and a bunch of DIY stuff comes up for pottery studios, which look pretty simple, cheap and straight forward.
Post by Tony Smith »
Agreed. The Gleco Trap is the way to go.
Dolores
Post by Dolores »
Thanks everyone! The Gleco trap looks like it will do the trick.
DOLORES
Yup, the Gleco works beautifully and it's relatively easy to buy and install. The only difficulty I've found is making sure there's sufficient space for it under the sink. Also, you've got to be sure to check it as often as the manufacturer recommends--when it fills up, it's useless, but you (or at least me) will continue using it as if it's working...
Post by Barry Kaiser »
I've got a Gleco and it is easy to install. After cleaning it out the first time, I realized how much good it really does. The swarf packs like concrete. It can really do a number on your plumbing.
Barry
Morganica wrote:The only difficulty I've found is making sure there's sufficient space for it under the sink.
There are four different sizes. You can measure the distance from the trap to the floor to find the right one for your sink.
Dolores
Post by Dolores »
I ordered the Gleco for my studio redo. I learned from the sediment in my Revolution saw tray just how rock-like that swarf can get and didn't want to repeat the experience in my new sewer line!
DOLORES
