I was given a small kiln with a Watlow 982 controller. I read the manual...no, I TRIED to read the manual. Can anyone give me an example, entry-by-entry of what needs to be programmed in for a simple glass fusing type program? I think if I had an example, it might make more sense and I could then adapt it as needed. Thanks so much!
Cynthia
Watlow 982: How do you program this darn thing?
Re: Watlow 982: How do you program this darn thing?
Cynthia
I don't know this controller, but I do know controllers in general. There are 2 styles of programming. The one most people here have, is degrees per hour. I'll bet yours goes from setpoint (temperature) to setpoint, over a specified time. Then you have to figure out how to stop the program until it reaches your programmed setpoint. This is an alarm function.
Watlow has a very good tech help department. I have used that, as I use their relays. Go to their website and look up the phone number. I've found the people there quite helpful. Tell him that you want to program ramps and holds both up and down, including a drop to anneal range, that starts the clock when the setpoint is reached. Ask if your controller can be used with a computer interface. I believe their software comes at no cost, but you need to add a device that works as a port to connect the computer.
Hi-
If you have the manual (watlow981_982.pdf) which is available for download, chapter 7 is how to program. There is a specific example on page 9 (7.9), and runs from 7.9-7.11
If you need the file, email me and I can send it to you.
"Everyone" says that this is a pretty easy to program controller. I am with you, it isn't particularly intuitive.
Guy
Guy
Thanks Bert and Guy. Appreciate the guidance!
