Fantasie and Samba (Ferro)...the info supplied with these products suggests that you heat them before you mix the powders with the mediums.  I have looked in the archives and can't find a mention of this.
Does anyone heat it up?  Is it a smoother blend if you do?
Any tips on mixing would be appreciated.
Cathy
						TO HEAT OR NOT TO HEAT...THAT IS THE QUESTION
				Cathy Crain
				jerry flanary
