slumping molds
lorimendenhall
slumping molds
Post by lorimendenhall »
is there a way you can use random ceramic items for slumping molds if you drill holes in them? I don't think you can but why not? I'm talking like using a plate out of your cupboard as a mold for example.
Re: slumping molds
For best results you need unglazed ceramic ware, commonly called bisque ware in the ceramics business.
If the item is glazed (as anything in you kitchen cupboard would be), then it's best to sandblast the glaze off. It's riskier, but if you're willing to sacrifice the item, you might try it anyway without blasting -- it's harder to get kiln wash to stick, but sometimes you can get away with that if the sides aren't too steep.
Lauri Levanto
Re: slumping molds
Post by Lauri Levanto »
Isn't it easier to take a plaster master mold and model a new clay mold with it?
That way you can eat and save your plate.
Re: slumping molds
See this thread, everything you wanted to know but were afraid to ask.........Jen
http://www.warmglass.com/phpBB/viewtopi ... =2&t=40145
lorimendenhall
Re: slumping molds
thats great info, thank you for posting
Re: slumping molds
The problem with slumping directly into a lot of dishware/serveware is that you're slumping into the inside shape of the vessel. The outside/bottom of the dish is designed to sit flat and give a particular silhouette, and that's usually what you want.
The inside of the dish is usually smoother and rounder so that it's easier to clean/eat soup from/whatever. That means the glass slumped into may not sit flat and may not give you the shape you want.
That's not to say you can't modify the dish to get it the way you want, but it's more work.
One caution with using ceramics to make slumping molds: Unless you're using a flexible mold material, i.e.,one that can be peeled away from the dish, think about how you're going to get it OUT of the mold. Even without undercuts, suction and the draft of the piece can get it stuck in the mold. Use plenty of release, and keep compressed air around to help separate them.
Re: slumping molds
In the industrial ceramics world, they make molds, using the same process as they use to make kiln shelves. They call these molds saggers. They are designed to hold plates during the final decorating firing, so the plates hold their shape. These make good slump molds. I bought some from Shenango in PA, many years ago.
