Hello all.
Is there any reason why failed lead crystal casting can't be broken up, cleaned up and recast?
It sounds too simple. Anything I need to watch out for?
Peter
recasting
recasting
Peter Angel
Re: recasting
Hi Peter.
I have had no problems reusing crystal. I mainly use blackwood.
Obviously try to ascertain why the original failed.
Max
Max
MaK
Re: recasting
No reason I can think of, as long as you cut off any parts with obvious scum/devit. You might have trouble with striking or maturing colors--opalines lose some translucency, you've got to be careful with reds, etc.
Depending on how/what failed you can also just recast your failure as-is and see if you can bring it back. Just reshape/correct the casting with organic wax (I melt beeswax and lard together) to fill in the voids. Encase it in your mold mix, with a reservoir(s) over the spots that will need more glass, and refire.
Max, I envy Blackwood users. Can't get it over here, have heard so much about it, would love to try it.
Re: recasting
Cynthia, blackwoods might ship to the US. And if you ship by sea (3-4 weeks delivery) rather than air (1-2 weeks delivery) postage is less than you think.Morganica wrote:
Peter
Peter Angel
