CoreLite Kiln Shelves
Can CoreLite kiln shelves be used with glass? Are they easy to cut if the size needs to be trimmed down from a larger shelf?
Re: CoreLite Kiln Shelves
I use them. I purchased from Seattle Pottery and they happily cut them to size before shipping.
They work fine with glass and can be cut with a tile saw just like a regular mullite/cordierite shelf. It's better if you cut across the hollow pockets, rather than parallel to them.Nbolinger wrote:Can CoreLite kiln shelves be used with glass? Are they easy to cut if the size needs to be trimmed down from a larger shelf?
Corelite shelves work fine for glass. The lighter weight is a real plus.
Just a reminder, the recommended heating and/or cooling rate for corelite shelves is only 200 degrees per hour.
i have corelite kiln shelves for my "papa" kiln and love them! i do ramp up 366 dph on initial firings and 250 dph for slump firings w/o a problem.
D
D
I have 3 that I use consistently. I have found that they do not like pot melts, but I love them for everything else.
Tim Yardic
Yardic Glassworks
Yardic Glassworks
