Fusing 19" dia. dichroic sheet to clear SPE 96
How do I avoid trapping air bubbles when fusing this size material?
Re: Fusing 19" dia. dichroic sheet to clear SPE 96
See this thread: http://www.warmglass.com/phpBB/viewtopi ... =2&t=40939BobAde wrote:How do I avoid trapping air bubbles when fusing this size material?
One additional comment -- if you fuse with the dichroic on top, you will have more trapped air bubbles than if you fuse with a thicker glass on top. That's because the thicker glass will help to push bubbles out.
