Glass turning silvery grey
Cheryl
Post by Cheryl »
So...what causes glass to turn silver grey? I have been having this happen with white and yellow glass lately, at all sorts of firing temps. It almost has a fumed look. Firings have included all sorts of other colors.
--Ralph Waldo Emerson
Re: Glass turning silvery grey
Is it irid glass? What are you firing with it?
Cheryl
Post by Cheryl »
just standard BE white. Not sure what you mean by what I'm firing it with. On kilnwash, mixed color loads. Nothing that I know of that should fume.
Peter Angel
Post by Peter Angel »
Does the silver grey look metallic?
Peter Angel
Mike Jordan
Post by Mike Jordan »
Have you fired anything else in the kiln or on the shelf you are using other than BE glass? Like, clay, metal, or other types of glass?
Mike
That kind of glass won't turn silvery grey without some sort of contamination in the kiln. Have you fired anything unusual in the firings prior to having the trouble? Fired anything other than just glass? Changed the kiln wash/shelf paper/kiln shelf/whatever? Used enamels/paints/inclusions/metals/whatever?
If you can, try a piece of the same glass in another kiln to see if the problem happens again. (Preferably someone else's kiln in another location.)
bob proulx
Post by bob proulx »
I am wondering the same thing, did you fire silver or metal clay in the kiln.
Previously fired silver stain?
