Bubble block progress, not.
Haydo
Post by Haydo »
Below are first two attempts at bigger bubble blocks. Schedule is a combined effort between 100mm cast and a 30mm anneal, I was before myself when I thought I had it nailed. Have a few thoughts how to correct two very different failures, it's bloody science. I'm going back to a stack of clear and only a couple of colour sheets until I can even begin to think about control for size and position. Have backed away from everything else to concentrate on these and cane for what I call octopus skin slab. Heading to Canberra for a 90th this weekend so will make time to check out the glass for inspiration. peace, haydo
second attempt 003.JPG (33.38 KiB) Viewed 31246 times
Jennifer Polver
Re: Bubble block progress, not.
Post by Jennifer Polver »
I love these. They are really stunning
Tammy Macdonald
Post by Tammy Macdonald »
Wow, just WOW! I look forward to seeing what you consider PROGRESS. These are fabulous.
Dolores
Post by Dolores »
Facinating ebb and flow on these, Haydo.
DOLORES
Warren Weiss
Post by Warren Weiss »
Haydo,
The two bottom photos are gorgeous. I have never seen this kind of work before. I searched "bubble block" but found nothing. If you don't mind sharing, I would love to know the technique involved. Thanks.
Warren
I do not know or understand what or how you are doing this.
But they are AMAZING. BEAUTIFUL.
Haydo
Post by Haydo »
Thanks all, wasn't until I sliced them up to see what was happening that I was less disappointed. These spend so much time in the kiln for a relatively small piece that it frustrates, pacing, waiting for the birth,
Warren there are other glass workers getting bubbles into glass, not sure how they do theirs. Bubble blocks is only what I call my work with the idea. I've tried so many different ways,organics, leaving space in lay up even now still having to come up with new tweaks. peace, haydo
Barb R
Post by Barb R »
These are wonderful! Love them.
Barb
Babette (Shawn)
Post by Babette (Shawn) »
You are onto something here, the Haydo technique! I agree with you, stop everything else (for now) and dig into this. I love the colors too!
― Pablo Picasso
I do something like this on a very small scale (I call it mockume gane) with pattern bars for murrini, but I really love it writ large like this, Haydo. Absolutely gorgeous. I'm not sure what you're after, but as far as I'm concerned you could stop right here and use this for all kinds of things.
If it's any consolation, I've never done one of these that wasn't disappointing...on the exterior. Like a geode, the exciting part is cutting it open. ;-)
Leonard Cichowski
Post by Leonard Cichowski »
So cool on so many levels...........love what I am seeing !
Haydo
Post by Haydo »
Happy that you all like them. I'm not going to give away too much but thought by sharing results from trying something new will not always end in tears, I will cry though at some stage if I keep getting these. peace, haydo
Studiodunn
Post by Studiodunn »
Way cool!
- Martin Luther King
