Spectrum label "ghost"
vblue
Post by vblue »
Anyone else seem to have problems getting the faint image of the Spectrum label off the glass? (Its not a residue from the adhesive, I don't think.) I've used glass cleaner and alcohol. Any other suggestions?
Thank you,
Vernelle
Re: Spectrum label "ghost"
Post by Kevin Midgley »
Use Bullseye glass instead? :lol: :lol: :lol:
vblue
Post by vblue »
Kevin Midgley wrote:Use Bullseye glass instead? :lol: :lol: :lol:
The only problem with that is that BE doen't have the "baroque" pattern on any of their glass.
Cheryl Maahs
Post by Cheryl Maahs »
I use WD40 to remove the "residue", then nail polish remover
pshash
Post by pshash »
There's also a product call Goo Gone. Then I would wash the glass with dawn dishwashing liquid.
vblue
Post by vblue »
pshash and Cheryl...Thank you for answering but you misunderstood my problem. Glass cleaner took off all the label. There is no glue or label residue. This is more like a stain.
Judd
Post by Judd »
It is glue residue, you just can't see it. Use the products described and it will be gone. I use Windex, or the generic equivalent, and a razor blade.
Or, the Kiln Gods are displeased with you.
Post by Marty »
razor blade, then acetone, then glass cleaner.
Of course that's on Bullseye, your mileage etc.
Magic Eraser works great.
Post by DonMcClennen »
That Ghost disappears when fired I've found.
Post by Laurie Spray »
Fine steel wool and windex......always on mynwork table! You would think however they could use another brand of lables!
Andrea R
Post by Andrea R »
Cheryl Maahs wrote:I use WD40 to remove the "residue", then nail polish remover
Seems like a lot of work to get a label off :shock:
"C'est Moi (Its Me)"
vblue
Post by vblue »
I can usually get the label off with just glass cleaner. Occasionally I let the glass cleaner set a soak a little bit and the residue comes off. I have never had to do any of what the people here suggested to get a label off.
You cannot feel anything with this "ghost" or shadow. You can just see where the label was. I tried Goof Off and the magic eraser. It didn't affect the shadow. Hopefully it will burn off as Don suggested.
calcium carbonate, aka whiting, the traditional glass cleaner.
But I still think you could try using Bullseye glass as it might be easier. :lol:
Andrea R
Post by Andrea R »
Kevin Midgley wrote:calcium carbonate, aka whiting, the traditional glass cleaner.
AKA Bon Ami?
I use standard window cleaner, but I run a razor blade across the labels to open them up, then saturate with window cleaner and let it sit for awhile. You need to dissolve the adhesive, and that takes a little while. If you rush it, you're more likely to leave residue.
bonami has other stuff in it like feldspar and is $5 a small can. A 50 pound bag of whiting from Greenbarn pottery supplies is probably $20
I guess it depends how many spectrum labels you have to remove. I keep saying use bullseye. :lol:
Cheryl Maahs
Seems like a lot of work to get a label off :shock:[/
Maybe ... But as I said ... It's what I use ... To each their own
charlie
Post by charlie »
[quote="Cheryl Maahs"][quote="Andrea R"][quote="Cheryl Maahs"]I use WD40 to remove the "residue", then nail polish remover[/quote]
Seems like a lot of work to get a label off :shock:[/quote]
Maybe ... But ... WD40 is fish oil and behaves like Goo Gone and the polish remover finishes it off. I would rather take extra steps to be absolutely sure than to find out the hard way after the firing. Just my humble opinion tho ...[/quote]
wd40 is not fish oil. it's mostly a kerosene-like product and an aerosol.
