pitted shelf
				jim burchett
pitted shelf
Any suggestions on how to permanently repair a cpl of small pits in a mullite shelf? I have tried making a paste of kilnwash and putting it in with a putty knife, but it doesn't last.
Re: pitted shelf
JenKen supplies a paste-like patch material for their fiber kilns. I've applied it with a putty knife, let it dry, and then sanded smooth. Its held up for about a year so far. Might work on the shelf too.
Re: pitted shelf
I recently purchased some Ceramic Coating made by Primo Primer that is supposed to solve this problem.  I then purchased a perfect new smooth shelf so I have this unopened.  If you want to try it email me!  To read more about it go to Ed Hoy and look under Primo Shelf coating I think.
				jim burchett
Re: pitted shelf
I had gotten a tube of refractory fiber caulk which I am trying as I write...it is a bit grainy but will possobly sand smooth..or smoother than the divots. Thanks laurie, I'check that out
Re: pitted shelf
I once made a putty using colloidal silica hardener, and dust from a vermiculite board.  The dust was easy to make, just rub sandpaper on a piece of vermiculite board.  The putty was easy to apply.  Once fired in, it can be sanded again.  It seemed to be durable.  I did this at somebody else's studio, and it worked remarkably well. You must use a good coat of kilnwash on top of this.
				Yardic Glassworks
Re: pitted shelf
Usually once I figure out howm much money and time it's going to cost to try and save a shelf, I end up buying a new one for about the same and cut up the old one for dams....
							Tim Yardic
Yardic Glassworks
						Yardic Glassworks
