Hello,
I can't find any info on whether or not twisted fiber rope can be used more than once. After one firing, can/should I soak it in kiln wash or primo primer to be sure?
In general I am having a difficult time understanding when any release agent should be reapplied to the fiber kiln shelf, to molds, etc. How can you tell?
Since I never fire directly on the fiber kiln shelf I am confident it is ok to reapply kiln wash only after 10 firings. Slumping molds - I take off old and apply fresh primo primer after every slump.
Thank you!
Twisted Fiber Rope - Can it be reused?
Deive Butvila
Re: Twisted Fiber Rope - Can it be reused?
I use fiber rope over and over. Eventually it loses strength and breaks apart. I like to run mine through some powdered alumina hydrate. This makes it reusable over and over, regardless of what temperature I fire to. Kilnwash contains Kaolin, which after a quartz inversion, can leave scummy marks on subsequent firings. Alumina hydrate is the other ingredient in kiln wash. This is not a problem with alumina.
I have some stainless steel rings inside which I like to fuse large frits in to circles. I line the ring with powdered fiber rope, and I can re-use it many times. The rope is a good shape for not creating needles around the edges of the glass.
Deive Butvila
Bert,
So much useful information in your reply!
Thanks for sharing both personal knowledge and technique.
Regards,
Deive
Regards,
Deive
