CAN I FUSE W/ NICHROME WIRE???
I'm doing a big fused glass school project with 50 kids to raise funds. We are creating some large wind chimes and need a way to connect all the chimes. I thought I would use nichrome wire but am not sure if it is compatable with Bullseye. I would be so thankful for an answer or if anyone has a better solution for connecting the pieces.... I have used copper before but it muddied up the glass around where I used it so I didn't want to go that route again. Many Thanks!!!... Regina
Re: CAN I FUSE W/ NICHROME WIRE???
Yup, You sure can.jewelme wrote:I'm doing a big fused glass school project with 50 kids to raise funds. We are creating some large wind chimes and need a way to connect all the chimes. I thought I would use nichrome wire but am not sure if it is compatable with Bullseye. I would be so thankful for an answer or if anyone has a better solution for connecting the pieces.... I have used copper before but it muddied up the glass around where I used it so I didn't want to go that route again. Many Thanks!!!... Regina
Jim
nichrome is great for what you want to do and won't muck up the glassjewelme wrote:I'm doing a big fused glass school project with 50 kids to raise funds. We are creating some large wind chimes and need a way to connect all the chimes. I thought I would use nichrome wire but am not sure if it is compatable with Bullseye. I would be so thankful for an answer or if anyone has a better solution for connecting the pieces.... I have used copper before but it muddied up the glass around where I used it so I didn't want to go that route again. Many Thanks!!!... Regina
D
http://www.mcmaster-carr.comKathie Karancz wrote:What the heck is nichrome wire and where do I buy it??
it's high temp hard wire....
D
