graphite
mikefromitaly
graphite
Post by mikefromitaly »
Hi.
i would like to know how to cut Grafite Plates.
thank you
mike
thanks for sharing !
mike from italy
"secret of success?... passion & experience"
http://www.picturetrail.com/mikefromitaly
charlie
Re: graphite
Post by charlie »
you buy them. it depends upon how big you need. marble or bead makers use them. you can probably get them off ebay cheaply.
Re: graphite
mikefromitaly wrote:i would like to know how to cut Grafite Plates.
A diamond saw blade will cut graphite.
The Hobbyist
Re: graphite
Post by The Hobbyist »
Graphite machines very nicely with nearly any cutting tool, even hand tools. The big problem is handling the shavings. When I work it I keep a vacuum constantly cleaning the cutting site so they don't fall or float about.
Jim "The Hobbyist"
Sean McFeely
Re: graphite
Post by Sean McFeely »
I agree with the hobbyist. If you are not careful to manage the dust you can and will short out your bushings on your electric motors as the dust is a conductor.
