Hi,
I'm looking to get an angle grinder but I don't have a water supply in my studio. Is it possible to use one without water? I think I've heard of using oil? Or is it possible to rig up a water supply with a bucket hung high?
Sandy
angle grinder without water supply?
Re: angle grinder without water supply?
Look for PVA grinding discs. Made for marble, but will work on glass.
A lot of people use them inside large, plastic storage tubs to contain the spray. Then you only need enough water to cover the glass.
I was lucky to find a backpack sprayer on sale, cheap. This works fine for my wet grinder and my wet saw. I wear the water on my back and give it a pump or 2 every now and then.
it's not much water. i used to use a 2 gallon jug with a hole and tap in the side up high on a shelf above my wbs for this. most of the stuff you can get at home depot in the garden sprinkler aisle: drip system stuff.
thanks everyone! any suggestions on which grinder to buy or what features to look for?
Sandy
Sandy
If you are buying a grinder anyway and have the money, buy a wet grinder now, and you will have it for when you do get a water source. I like the Alpha but Bob has stuff to look at on His Glassworks, so check them out.
