Pieces of kiln stuck in fused glass
Shelley Lewis
Post by Shelley Lewis »
A few small pieces of my kiln apparently fell onto my glass when I closed the lid prior to fusing. Any way to remove them from the fused glass?
Re: Pieces of kiln stuck in fused glass
Post by Marty »
Drill, grind, or sandblast them out, fill with frit or something else and refire.
Or cut the offending parts out and reuse the clean pieces.
More important- if they didn't come from dropping the lid (you should have opened and checked before firing), you need to fix whatever's causing the debris.
