Over lapping stainless steel molds
vblue
Post by vblue »
I have two stainless steel weaving molds. The original is 7" x 16" that I purchased years ago from Mike Fraiser. When he stopped producing the molds, I took the mold to a metal manufacturing company and had a 15" x 15" mold made. I need a couple more inches of mold space to make the size weave I want.
Can I put one mold on top of the other with more weaving space exposed or put one mold on the shelf and the larger one on small kiln posts above it? The glass would only go on the exposed part of the mold.
My concern is the heat where the molds overlap......could this cause problems?
Hope this makes sense.
Vernelle
Re: Over lapping stainless steel molds
Post by Kevin Midgley »
I'd go for it. All you lose is a bit of glass if it doesn't work.
If you are worried about that, test with a couple of strips of glass.
Testing is the only way you will know what will work in your kiln.
