I just installed a 200 lb table top.  Normally this would be routine for me.  In the middle of this process, I had hip replacement surgery.  So challenge one was taking delivery of 2 hundred pound pieces of glass, getting one clean, on to my light table, painted, then loaded in my kiln, while being a cripple walking with a cane in my right hand.  I did that.   I pre-fired it, and then cleaned and loaded the top piece with the help of a friend.  To do this job, I bought a garden wagon and a 500 lb hydraulic lift table.  For years I have been envisioning this rig to get glass from cutting bench to light table to kiln to truck.  I finally bit the bullet and bought it.  It works pretty good.  I fired the glass.  Then I had hip replacement surgery on Tuesday.  On Friday, my client came over with a helper and I got them to slide some 2x4's under it, slide the glass over, tip it up, and hold it while I cleaned off the bottom of the glass.  Then we reset it down on the 2x4's ready to transfer to a truck.  The next day they came back with the truck and we got it in and over to their house.  The table legs had been built.  BTW there is a notch in the glass to fit a pole that was in the way of where we wanted the table, so I had the glass supplier cut the notch out.  We fixed some issues with the framework (installed the refrigerator first) and then a couple of young fellows carried the glass up a short flight of stairs.  I have special grips for this.  We set the glass on the framework.  I never know how the two will interface, as neither are perfectly flat.  We were pretty lucky, and the 3 points of contact were in the right places.  We slightly lifted and goobered in a bit of silicone, then a bit more around an about to glue it in place.  Basically I was the supervisor.  The crew was good.  I didn't stress myself out,  Yipee!  Here are some pictures.  The post needs to be trimmed out with a covering, and the room needs to be painted and finished out.
The painting is done with Ferro Sunshine Series on glaze colors mixed with micas. The painting is far and away the fun part of the process.
