I have searched the archives both new and old, and ran across a posting from Lani that explained the process, but it didn't address my particular situation.
I have a commission to make a project with BE 0146 steel blue Tack fused on the surface. I understand that this is a very unstable glass and should be tested whenever you use a different run. I would like to do this, but the customer is in a hurry, and I would rather not put him off for a couple of days while I figgure this thing out.
I want the glass to remain blue.
My tack temp will be about 1350, which is right in the middle of the color shift.
I would like to know if anyone has experience with an overglaze such as spray a, super spray, or bending glaze to prevent the color shift.
And if they have, what were the results?
Capping with clear is not an option.
Thanks.
Jim
0146 BE steel blue question.
jim simmons
Jenefer Ham
PDXBarbara
Re: 0146 BE steel blue question.
Hi Jim... try a fast test in your Quick-Fire with the little controller you made. (Yeah, yeah, you already thought of that and there's a real good reason not to, etc....right?)jim simmons wrote: I would like to do this, but the customer is in a hurry,
Would a color close to steel blue -- like 0164 -- be close enough for jazz?
xxoo
Barbara
Barbara Bader
Ron Coleman
Jim
It will most likely turn silver at 1350. I've seen it turn as low as 1175 during a slump.
What I would try is something like bending glaze or "back magic". Cut your glass and finish any edges and then apply the glaze and tack fuse.
If you can find the Ferro Frit #3419, it melts starting at 1000 and has a nice gloss by about 1200 f. Check local pottery suppliers. I have used it on steel blue and it works.
Ron
Ron
jim simmons
Yo, Barb. I did just that, but the results were inconclusive. After talkimg to BE, it was decided that I had to do a test of every new batch in the same kiln and same firing schedule that the main project was going through. They said it was a product of time, temperature and atmosphere.PDXBarbara (Bader) wrote:Hi Jim... try a fast test in your Quick-Fire with the little controller you made. (Yeah, yeah, you already thought of that and there's a real good reason not to, etc....right?)jim simmons wrote: I would like to do this, but the customer is in a hurry,
xxoo
Barbara
It is going in the kiln today with Bending glaze like Ron suggested.
Jim
jim simmons
Thanks, Ron. I will try the bending glaze, as that is what I have.Ron Coleman wrote:Jim
Ron
Jim
