Disposing of ground glass
helenM
Post by helenM »
Hi, I've just bought a diamond pad to grind some glass edges before fire polishing (and to learn how to use it - just bought Paul Tarlow's book to help, excellent book) but I was wondering what the best way of disposing the waste glass is. I thought I would do the grinding in water, let it settle then drain of what water I could and throw the rest in a plastic bag and wrap up for throwing away in my normal waste.
What do other people do when coldworking? I live in the UK so I'm not sure if there are any rules about this (may have to do a bit of research on that). Also I like to be as ecofriendly as possible when disposing of waste craft products.
jim burchett
Re: Disposing of ground glass
Post by jim burchett »
I,personally do not consider ground glass as a hazard to anything but plumbing. I treat it as I would diatomaceous earth and spread it around plants in the garden.
Ditto. Pour it on the plants.
helenM
Post by helenM »
Thank you!
Ed Cantarella
Post by Ed Cantarella »
Just run it down the largest drain in the house - probably the toilet. Seriously - you've probably washed larger grains of sand off vegetables from the store.
DON'T put it down the toilet if you have a worm-powered sewage system. It'll tear their little guts out!
Post by Marty »
Don't put it down ANY drain.
Ed Cantarella
Marty wrote:Don't put it down ANY drain.
OP is only talking a little powder - what's the harm? Glass is sand(roughly), sand is glass. We all habitually wash dirty clothing with embedded sand down the drain and same for dirty vegetables,dogs, etc. And we eat a fair amount which comes out . . :mrgreen: . https://health.howstuffworks.com/wellne ... t-year.htm
But I would fully agree that one shouldn't dump grinder sludge down a drain - the particles are much too large to be carried away and could start to accumulate in the trap (u-shaped piece on the drain pipe).
Terry Crider
Post by Terry Crider »
Any thoughts on washing very small brushes out in the bath room sink --- Brad's and Barry K's "paints"
Post by Barry Kaiser »
Terry,
The politically sensitive answer is to not do so.
I did it all the time. Our paints contain very little (relatively) solids and those are ultra fine.
However, I have now installed a Gleko Trap since I do a lot (and I mean a lot) of painting and washing. After the first year, I cleaned out the trap and it was amazing how little solids there was.
Barry
I have a Gleco trap on my utility sink. I wash anything glass related in that sink (glass itself, brushes, etc). If the piece is small enough, I'll coldwork with handpads in that sink. The grinder sludge, I scrape out and dispose of. Other coldworking water usually ends up in the yard (the water bucket for the lap grinder & saw).
The utility sink is also great for washing dirty vegetables :) .
