Dried up
josie
Dried up
Post by josie »
I recently relocated. A lot of my stuff has been stored for a year. I have a set of TE marking pens and glassline enamels. both have dried up. any idea how best to rehydrate them?
josie
Re: Dried up
Post by josie »
will do. it is too bad. paints such as watercolor may be rehydrated. trying a bit of water in the Glassline bottle. if it works i may pry off the ends of the pens and add a drop or two.
Re: Dried up
Post by Kevin Midgley »
Glassline needs to be shaken and or vibrated for ages and ages with the addition of water. This may help too..... [-o<
Re: Dried up
I wouldn't add water. I'd add propylene glycol. Maybe soak the tips in the glycol.
josie
Re: Dried up
Post by josie »
thanks for your replies
jim simmons
Re: Dried up
Post by jim simmons »
OK, Bert. Where can a normal person off of the street buy it in quantities less than 50 gal.?
Jim
Bert Weiss wrote:I wouldn't add water. I'd add propylene glycol. Maybe soak the tips in the glycol.
Re: Dried up
jim simmons wrote:OK, Bert. Where can a normal person off of the street buy it in quantities less than 50 gal.?
Not hard to find. Amazon carries it.
josie
Re: Dried up
Post by josie »
isn't propylene glycol anti-freeze?
josie
Re: Dried up
Post by josie »
thanks jim. i think you are correct.
carol carson
Re: Dried up
Post by carol carson »
I've used Glassline for years and have always reconstitutes them with water, no matter how dried up they were, it worked.
josie
Re: Dried up
Post by josie »
i tried a little water and then fired a sample and it seems to have worked. now if i can get the pens reconstituted.
jim simmons
Re: Dried up
How long did you have to shake it?
I just shook 2 bottles quite vigorously for 10 min. each with almost no reconstituting
Jim
josie
Re: Dried up
Post by josie »
not long at all. i used the blue. the rest are soaking to see if it makes a difference. this is the squeeze bottles, not the pens.
Re: Dried up
Shake is a general term.
A back massager has a second use in this case.
I must admit being tempted to fill a paint can with dried bottles well capped and taking them to a paint store for having a run through their paint mixer machine.
Re: Dried up
I talked with the Glassline folks a couple of years ago at the Glass Expo. They say to just add some water, let it sit overnight, and then "shake vigorously".
jim simmons
Re: Dried up
That sounds like a heck of an idea. fill the spaces between the bottles with sand to keep them from moving.
Kevin Midgley wrote:Shake is a general term.
Re: Dried up
tape the caps on if you try it.
Re: Dried up
Ethylene glycol is regular antifreeze. Propylene glycol is non-toxic antifreeze often used to winterize RV's and heating systems. I buy it as food grade from bulk apothecary, online,
Recon requires a palette knife on a glass palette. I use a cake spreader that is pretty stiff for my palette knife, along with a smaller artist's one.
A medium consists of a vehicle and a binder. The glycol is the vehicle, and I use gum Arabic mixed with the powder for my binder. I'm sure there are other ways binders can be incorporated. I also mix in glycerine to slow down drying. (Glycol and glycerine both start with the same root glyc, so I assume they are first cousins).
I was taught to paint on small pieces of glass for stained glass windows. I had to adapt techniques to work on large pieces of glass. Slowing down the drying was the key to working large. I can put the glass in the kiln to dry it, if I need it dry right away. You can fire wet if the painted surface is on top. The glycol lowers the freezing point and raises the boiling point. The result of the higher boiling point allows for the paint to dry before it boils. This is really good for us, allowing us to fire wet paint without it messing up. If it were to boil, you would see visual result of the pigment moving around.
