The right torch for bullseye rods
Maggie Abdel Rahman
Post by Maggie Abdel Rahman »
I tried to make little leaves using bullseye rods. I used a dual-fuel torch (oxygen and propane), but the glass colors changed and the clear glass rod turned greyish. Is a single fuel torch better with soft glass ?
Tom Fuhrman
Re: The right torch for bullseye rods
Post by Tom Fuhrman »
Dual is required, but it must be surface mix, not premix. I've been using a Nortel minor for many years and now have switched to a Bethlehem Alpha, You also have to have your flame adjusted correctly and work way out in the end of the flame.
Maggie Abdel Rahman
Many thanks Tom
Maggie Abdel Rahman
Thank you for your tip Jim
