Ok. Here's the nightmare. Element pin released the heating element and it fell into the glass. glass cooled and element got stuck in glass. When I lifted the lid unknowing that the element was stuck in glass, the element broke in two. Of course I have to make a full fuse and a fire polish fuse before friday show. Other than replacing the element, is there any way I can still fire the kiln? Can I somehow just twist the wire together? can I fire the kiln with the element apart? Can I throw a tantrum and make it go away?
Help with some good news....
thanks,
Peter
major heating element disaster
Re: major heating element disaster
Potters make emergency, temporary element repairs by heating and then twisting the broken ends together. So it may be possible to get a few more firings from your element. I don't know because I haven't seen your element.peterbr wrote:When I lifted the lid unknowing that the element was stuck in glass, the element broke in two. Of course I have to make a full fuse and a fire polish fuse before Friday show. Other than replacing the element, is there any way I can still fire the kiln?
The kiln manufacturer might be able to overnight another element to you in time to complete the firings before Friday. That might be the better choice.
Sincerely,
Arnold Howard
ahoward@paragonweb.com / http://www.paragonweb.com
Years ago I repaired a dryer heating element by bolting the ends together using a small bolt(screw) and nut, erector set size. It held for a long time.
Of course the dryer element doesn't get as hot as the kiln but I believe it is the same sort of material. For an emergency fix it might work.
Jim "The Hobbyist"
Jim "The Hobbyist"
Gentleman,
Thanks so much for the advice. Took both ends and folded them together so they overlap as one. Turned on the kiln and got familiar noise. Heat started rising and we are in business. Didnt run full cycle since not ready to full fire. Gonna run tomorrow. Fingers crossed. Just need these two runs. Getting elements replaced next week.
thanks again,
Peter
thanks again,
Peter
