precious metal clay
Thomas Decker
precious metal clay
I am thinking of adding some embellishments to a piece with pieces of precious metal clay. will the clay fuse to the glass? or will the glass crack because of incompatibility issues?
jim simmons
Re: precious metal clay
There are several different types of PMC. Some will work well with glass,some won't.
Try a test with what you have to see if you're successful.
If you want basically a glass surface "painted" with silver, I would look at using clay slip. Keep in mind certain glass colors will react with the silver (and the silver can contaminate your shelf).
Otherwise, your best bet is to create a bezel with the embellishments overlaying the glass. Most of the clays generally shrink about 10%. All provide a shrinkage spec in the product info.
COEs are not compatible, BUT thin application that Dana suggests will work. I screen print slip onto glass all the time .
You cannot add onto dichroic. Also, Cannot cap it. Will react with underlying glass, but often not noticeable
http://www.Kaiserglass.com
glass classes;
Tutorials; [/b]
Facebook:[/b]
glass classes;
Tutorials; [/b]
Facebook:[/b]
Barry, that sounds like a fun idea, any tips or tricks about screenprinting with PMC slip? Or even a link to photos showing what it looks like?
Thanks!
Thanks!
The middle row of pieces at
http://kaiserglass.com/page33.html
are all screen printed with silver slip.
Barry
Barry
glass classes;
Tutorials; [/b]
Facebook:[/b]
glass classes;
Tutorials; [/b]
Facebook:[/b]
