Stringer Storage
Steve Immerman
Stringer Storage
I'm trying to figure out a good way to store a gazillion stringers that I pulled in the glory hole. I'm thinking that if I could find some clear plastic tubing, like the "store bought" stringers come in I could make my own holders. So far, I haven't been able to find anything like that. Anybody have any ideas for a source for this? Or a better idea for storage?
Thanks.
Steve
Thanks.
Steve
Richard Sinning
Local Home center
Head for the home store and pick up some pieces of plastice pvc pipe and caps. Glue the caps on the end and voila, storage for stringers. A little strap hanger and they could be hung anywhere
Richard
Steve Immerman
Ron Coleman
Tubes and Caps aka clear mailing tubes.
http://www.uline.com/Group_74.asp
I've seen longer ones too.
Ron
Ron
Rebecca M.
Here's some more. Maybe a little less expensive. Check out the square tubes 2x24. They're on sale for .99 each. http://www.jcdanczak.com/our_products/cat_7.html
They sell hanging caps too which may be a good storage option.
steve, being an unreformed packrat, i believe i have a bunch of dichroic frit tubes - would these help? andyes, they are clear and have caps on both ends....Steve Immerman wrote:I had thought of that, but the PVC pipe I have is white. Does it come in a transparent PVC? I was kind of hoping to be able to see the colors.
Steve
D
Steve Immerman
Gordon Exon
stringer storage
the tubes they sell for shop vacuum systems are clear. i don't know about the economics but clearly the source is there
Alecia Helton
Kim Bellis
Robyn Alexander
Tap Plastics sells plastic tubes 36" long. You can see them at:Steve Immerman wrote:Dee - I need something at last a couple of feet long. Three feet might be best.
Camaro - do you mean flexible tubing?The shipping tubes might work, I just wish the were longer and narrower....
Steve
http://www.tapplastics.com/shop/product.php?pid=274&
Nancy Juhasz
Steve, Did you ever think of making your own out of plastic or acrylic sheets? This place seems to have the stuff http://www.plaskolite.com/optix-acrylic-sheet.htm
I don't have time right now to do a good search need to be someplace in 20 minutes. Maybe use a broom stick or something as your guide gor size You could buy the caps. Nanc
PVC pipe display
Ok, don't look at the mess around it, but this is how I store my rods for lampworking. I bet you could use the same for your stringers. If you lay them on their side your stringer could hang out a little so you could see what you had easily. I got these at Home Depot and they cut them for me for free. Lydia of Ohio
Geri Comstock
